11/11/2008 12:10 PM | |
Joined: 3/21/2006 Last visit: 3/19/2025 Posts: 10239 Rating:
Hi SIMATIC NET CD supplied with NCM PC and permits you to create PC projects and open STEP 7 projects. However, it is not possible to use this software to edit the S7 blocks in the STEP 7 project.In your case if you need to edit S7 blocks must order Step7. About OPC server: how do you configure an S7 connection for a user application via Industrial Ethernet with the SIMATIC NET PC software? |
