6/8/2023 10:43 AM | |
Joined: 7/19/2022 Last visit: 10/4/2023 Posts: 233 Rating:
Hello U_cf7082a6-618f-4..., This is because in the S7-1500 the program is stored on the Memory Card. Therefore, even if you do a factory reset of the PLC, the program will continue on the Memory Card until you delete it. |
