7/15/2014 9:32 AM | |
Joined: 8/25/2005 Last visit: 3/21/2024 Posts: 1161 Rating: (110) |
Hello James.Yang, which version of WinCC are you using? The document you haved linked is talking about WinCC Advanced. And you have published the question within the conference SIMATIC WinCC. Here we are talking about WinCC up to Version 7.2 Best regards Sabine |
7/15/2014 9:38 AM | |
Posts: 15 Rating: (0) |
Hello Sabine, I did open the project with TIA Protal, if this it what it means to be WinCC Advanced? Best regards James |
7/15/2014 9:44 AM | |
Hello James, so Moderators should transfer the question to the conference SIMATIC WinCC (TIA Portal). They are allready informed to do so. Best regards Sabine |
7/16/2014 4:44 PM | |
Posts: 1299 Rating: (135)
Hello, in chapter 1 they write:
In order to create access to an ODBC data source, you must create a data source. Data sources can be created in the Windows Control Panel under "Administrative Tools > Data Sources (ODBC)". How to create a Microsoft SQL database is described in Entry ID 61886098.The entry includes the principal configuration steps. |
