3/23/2016 5:01 PM | |
Posts: 7 Rating:
Can anyone helt, what this error is for? :O |
3/23/2016 5:19 PM | |
Posts: 7 Rating:
It is a newer HMI, and a V1 s7 1212C :) - Can i do something to solve the problem? |
3/23/2016 5:36 PM | |
Joined: 5/12/2006 Last visit: 4/24/2025 Posts: 22624 Rating:
Hello, you can update the S7-1200 to Version V2.2 then it should work.
Christoph |
3/23/2016 5:38 PM | |
Posts: 7 Rating:
Okay. :) |
3/23/2016 7:23 PM | |
Posts: 439 Rating:
Hello, You should take a look in the "Connections' of your HMI in the project tree. There must be a bad HMI connection which are in red. Best regards, Hugo |
3/23/2016 9:08 PM | |
Posts: 7 Rating:
Yes, there is a red error. But if i take a newer cpu, v2.2, it works just fine :) |
3/24/2016 4:25 AM | |
Hello, yes for the update you need a 24MB Memory Card. or look in this FAQ and show if you can use a alternative way for the HMI Access: https://support.industry.siemens.com/cs/ww/en/view/109475049 Regards Christoph |
