7/13/2017 10:11 AM | |
hi MustafaRaza, the latest version of Step7 is V14 SP1. You can project and programm both devices with it. TIA means Totally Intigrated Automation. Maybe this Link helps: The latest version of the classic Step7 is V5.6. Both versions are available in this page with a Trial-Licence: Where do you procure the current trial software for STEP 7 V5.6? SIMATIC STEP 7 including PLCSIM V14 SP1 TRIAL download hope this helps, regards, |
FCK WAR! |
7/14/2017 2:38 PM | |
Posts: 8946 Rating:
TIA is the abbreviation for the shortcut PITA. |
7/18/2017 3:48 PM | |
Posts: 5 Rating:
TIA is a Totally Integrated Automation Software in which you can Program PLC as well as designed HMI under same Platform of one Software. You can find more about TIA by accessing below links, https://www.youtube.com/watch?v=wnntZg3CHdI Latest version of TIA Portal is "TIA Portal V14SP1". Yes, you can use this software for mentioned both devices as above. |
