9/13/2012 4:14 PM | |
Joined: 9/27/2006 Last visit: 6/5/2023 Posts: 12033 Rating:
Hello Yann; If you mean a CPU 943B, the specs of the IM 151-8 PN/DP seem to be quite sufficient to replace it: S5-115U CPU943B : SIMATIC S5, CPU 943 FOR S5-115U PLC, RAM 48 KBYTES W. 1 PROGRAMMER PORT http://support.automation.siemens.com/WW/view/en/4063159 IM 151-8 PN/DP: SIMATIC DP, IM151-8 PN/DP CPU FOR ET200S, 192 KB WORKING MEMORY, INT. PROFINET INTERFACE (WITH THREE RJ45 PORTS) AS IO-CONTROLER, W/O BATTERY MMC REQUIRED http://support.automation.siemens.com/WW/view/en/42361392 Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 9/13/2012 4:22 PMLast edited by: dchartier at: 9/13/2012 4:21 PMLast edited by: dchartier at: 9/13/2012 4:14 PM |
