6/3/2011 10:27 AM | |
Joined: 1/4/2007 Last visit: 12/2/2024 Posts: 1152 Rating: (175)
Hello Palestine, If your application is a weighfeeder you can use either the: - Siwarex FTC (for belt-scales) OR - BW500 The Siwarex FTC (for belt-scales) has no PID-controller on board. That means you have to use the PID-controller of the S7-PLC to control the flow. The BW500 has an onbord PID-controller to control the flow. Attached the technical data sheets from both modules. Best regards Siwarexi Attachmentweighfeeders_BW500_FTC.pdf (344 Downloads) |
6/4/2011 12:35 PM | |
Posts: 74 Rating: (0) |
Hello Ayamn Thank you Ayman for your quick response [schnippschnapp] new question is splitted to Connecting Speed sensor to SIWAREX. Best Regards Ahmad
