10/4/2010 10:54 AM | |
Joined: 3/3/2008 Last visit: 10/5/2023 Posts: 333 Rating:
hi try to set the dip switches as per the cable used . the same is attached for your reference Attachmentcable distributor.pdf (138 Downloads) |
10/4/2010 11:37 AM | |
Posts: 259 Rating:
Thank you for your answer. But nobody change switch position and cable is the same so error is somewhere else... With regards, Makaveli |
10/7/2010 10:14 PM | |
Posts: 672 Rating:
Hi, Is it a new machine ? Have you set the switches in the cable distributor ? What system is it and is it new machine Pee |
