7/13/2011 1:29 AM | |
Posts: 14 Rating: (0) |
Hi everyone, im using pcs7 with F-Systems, when trying to compile charts i receive the error The maxumu number of lines that can be processed was exceeded for FC57, but the system itself is generating this FC so how can i correct this error, can anyone help me please. Splitted from CONVERSION SCL-->AWL (max number of lines). |
7/13/2011 8:19 AM | |
Joined: 3/24/2009 Last visit: 7/9/2024 Posts: 535 Rating: (112) |
Dear wolf08, Can you find out to which runtimegroup or task this FC belongs? If it's an F-group you can do this in the 'Edit safety program' dialog - after selecting 'Update' you can see to which chart / runtimegroup / task the block belongs. Having this information you can try to split the runtimegroup / task in two or more groups. If it's a system-group you can try to split the shutdown-groups using the F_PSG_M-block. But does it make sense to bring your F-Systems-project to the TIA-portal, where you do not have the safety-extensions yet? Hope this helps. Best regards, yy1 |
