12/20/2019 5:16 PM | |
Joined: 10/1/2018 Last visit: 7/24/2023 Posts: 9 Rating: (0) |
Thank you so much. This problem solved but I have another problem for now. when we turn off the PLC the local time changes to 0 and I need to connect to PLC and adjust the local time. Is it hardware and battery problem? or I can fix it in the software. PLC is 1214C. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/23/2019 07:11:41New subject after splitting |
12/23/2019 8:25 AM | |
Joined: 2/20/2014 Last visit: 1/14/2025 Posts: 405 Rating: (38) |
Hi, Have you enabled the clock memory byte under the PLC CPU properties/ Try enabling them & look for the results. |
