3/21/2022 1:01 PM | |
Joined: 5/25/2021 Last visit: 11/20/2024 Posts: 25 Rating: (1) |
Hi Rescobedo, Where did you manually inserted the encoder values, When I'm using telegram 105, I can only see window to enter Gx_XIST1 and T2 is not visible. Every time I do jog I have fallowing error and axis don't move. Do you have solution for this ?
Last edited by: Jen_Moderator at: 03/22/2022 08:32:57New subject after splitting |
3/22/2022 8:35 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (173) |
Closed cause question posted twice. The second thread with the subject Sinamic v90 with MT ABS Encoder Configuration is published within the conference SINAMICS general. Jen_Moderator |
