2/12/2008 11:18 AM | |
Joined: 8/25/2005 Last visit: 1/29/2025 Posts: 1162 Rating:
Hello sunil, I found this page serching within the product support: PROFIBUS GSD files : SWITCHGEARS Think Station type: SIMOCODE-DP circuit control / control unit will be that one you are searching for. Best regards Sabine |
2/12/2008 11:20 AM | |||||||||
Joined: 9/27/2006 Last visit: 2/13/2025 Posts: 12336 Rating:
hello sun7; If you need software to configure the Simocode-DP, you will need to contact a Siemens rep:
http://www.siemens.de/simocode-dp Briefly, the essential difference between the 2 packages is in communications between the PC and the Simocode: the Smart package gives access through RS-232, the Professional package alsoallows connection over profibus-DPV1. See attached document. Same for the PCS7 function blocks:
2/13/2008 8:17 AM | |
Posts: 152 Rating:
Thank you guys. Your support helped a lot. |
