10/26/2011 9:55 AM | |
Posts: 3037 Rating:
Hello, As far as I know you can only use the data type of integer for numbers without comma. You should use the data type of real. Tweety |
2/18/2016 4:06 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4839 Rating:
New question published by Duong Vo is split to a separate thread with the subject How to see change of a value of a tag when press button in WinCC Prof Tag Simulator?. Best regards |
