11/14/2020 2:58 AM | |
Posts: 1 Rating:
Hi All where do I find the install file to load up to the a new sensor prom thanks scott
Last edited by: Jen_Moderator at: 11/16/2020 09:22:06New subject after splitting |
11/14/2020 11:55 AM | |
Joined: 9/27/2006 Last visit: 9/28/2023 Posts: 12153 Rating:
Hello capelambertB; There is no link to a file for the sensorprom, to my knowledge. When you receive the flowmeter you ordered, calibration data is loaded by the factory on a "sensorprom" that you must install in the transmitter chosen for that flowmeter. The Siemens factory keeps an archive for each calibration parameter for every flowmeter they construct, idrntified by the serial number of the flowmeter tube. We have had to request a new sensorprom from Siemens after loss or destruction of the chip, and they were able to comply; but that was relatively soon after production, I do not know how long they would keed those archives. The MAG 5000/6000 Quick Start manual shows how you should set the sensorprom in the transmitter housing. https://support.industry.siemens.com/cs/us/en/view/109778902 This is the only manipulation a user must do with the sensorprom when installing the flowmwter. Is this the type of information you were looking for? If not, please clarify your question. Hope this helps, |
