7/10/2009 9:28 AM | |
Joined: 3/21/2006 Last visit: 9/10/2024 Posts: 10228 Rating: (1181) |
Hello, About memory card look at CPU 614 - Technical Data . There you'll find details about max. size. And for example you can use 6ES7 952-1KL00-0AA0. (compare with Mise à niveau du système d'exploitation pour S7-614 CPUs) Hope this will helps. Best regards, Hristo Mihalev |
7/10/2009 10:04 AM | |
Joined: 3/16/2009 Last visit: 4/24/2024 Posts: 7 Rating: (0) |
Dear UMENCHO |
7/11/2009 5:06 AM | |
Dear UMENCHO Thanks for your help! Best Regards |
10/8/2012 12:57 PM | |
Posts: 5 Rating: (0) |
Did you find manual for 6ES7 614-1AH00-0AB3? I saw answers for the MMC compatibility, but no answer for manual.
10/8/2012 4:20 PM | |
Joined: 9/27/2006 Last visit: 9/15/2024 Posts: 12282 Rating: (2683)
Hello dimigav; One of my early jobs working with Siemens products was as technical support for a Siemens Distributor in North America. I had to deal only once with a CPU 614, as a special request from a good client of ours, who had one mounted on a platics extruding machine. Even at that time (around 2000)the manuals and documentation for this product was very difficult to locate. The CPU 614 was based on a CPU 315, but it was a specialty CPU designed for the plastics industry, with specific technological functions unavailable elsewhere, developpedby the Alpharetta, Ga, branch of Siemens America. I was only able to transfer information to my client by agreeing not to keep any copyof any document related to the CPU 614. At this time all versions of the CPU 614 are discontinued, and entering cancellation phase: help on the product is only available through Siemens spare-parts management. The specialty technological blocks for the CPU 614 came through an executable file called ABGEN, and hereare the last available entries in the Siemens Product Support about that file: http://support.automation.siemens.com/WW/view/en/5768218 http://support.automation.siemens.com/WW/view/en/17253656 |
