3/13/2011 11:49 AM | |
Posts: 91 Rating:
Hello Ekalavya, Whether you have any procedure for "ethernet communication with TCU". we having 840D sl with embedded and HMI sl . i think both have different procedure. i think we should connect the ethernet cable to X130 port on ncu720.1. whether you have any procedure for this? Thanks for your help. Splitted from communicating with my machine. |
3/14/2011 6:42 PM | |
Posts: 2964 Rating:
Hi, Check out this....may be useful to you..... Regards, Ekalavya AttachmentIHE.pdf (258 Downloads) |
3/15/2011 7:32 AM | |
Posts: 91 Rating:
hello all, i already tried to communicate with X130 port. and check the connection status on Diagnostics --> Bus TCP/IP --> TCP/IP diagnost (please find the attached file). when we tried automaticwithX130 port shows inactive(not connected) then we set address manualy and restart the system then it connect fine, but we can't ping that address . Whether we want to use any software like for PCU20 HMI Embedded Network manager??? Regards Attachmentlogdrives.zip (152 Downloads) |
