5/3/2012 2:22 PM | |
Posts: 378 Rating: (73) |
Dear dears, Could you tell me the highest speed ( lowests scan time ) of CPU from S7-300? please tell me the order code and scan time Thanks |
5/3/2012 2:24 PM | |
Posts: 8946 Rating: (999) |
CPU319 |
5/3/2012 2:30 PM | |
Joined: 3/21/2006 Last visit: 9/10/2024 Posts: 10228 Rating: (1181) |
Hello, Do you have some details? Best regards, Hristo Mihalev
5/3/2012 2:35 PM | |
Joined: 9/28/2005 Last visit: 8/27/2024 Posts: 2957 Rating: (242)
Indeed this is the fastest. No one will tell you scan speed because it depends on your program and communication load. Download this manual SIMATIC S7-300 Instruction list S7-300 CPUs and ET 200 CPUs and here you will find execution times on various PLC. Then you can have more basic idea on the speeds. |
Best regards, |
This contribution was helpful to5 thankful Users |
5/3/2012 3:36 PM | |
Hi Darius Am not sure but scan time specified on SIEMENS CPU is the time taken to excute 1000 instruction, it's obvious the more instructions the higher scan time. Read the SIMATIC S7-300 Instruction list S7-300 CPUs and ET 200 CPUs then you can have basic idea. |
5/3/2012 3:42 PM | |
Try to use rubber - shock absorber. Also have a look to the "plus extreme" series of S7-300. |
5/3/2012 6:41 PM | |
Joined: 9/27/2006 Last visit: 9/13/2024 Posts: 12282 Rating: (2683)
Hello desmul24; You will find links refering to Siplus modules(ruggedized automation platform), resistant to high-vibration, in the following discussion: /tf/WW/en/Posts/72308 Hope this helps, Daniel Chartier |
5/3/2012 7:59 PM | |
For what type 1000 instructions it is specified ? Boolean logic, floating point or maybe indirect addressing ? Could you please point me to the page number of that manual where is specified S7-300 scan time for 1000 instructions ? |
Best regards, |
