2/24/2014 10:14 AM | |
Joined: 11/16/2012 Last visit: 3/22/2024 Posts: 227 Rating: (31) |
Hi jm1983, which version of PDM do you use and which license do you already have? If you want to use HART over Profibus DP or Profinet you will need the version V8.1. You find some additional information here, under "Product Information". Regards jumo |
2/26/2014 2:25 PM | |
Hi jm1983, the licenses are good. If you want to use routing functions, make sure that your hardware is compatible (e.g. CPU FW minimum V5.1). See additional information about PDM Data Record Routing in this FAQ. Hope this helps! Regards jumo |
