4/29/2016 11:35 AM | |
Posts: 107 Rating:
I understand that you have HMI prjects and you need to access them on your PC. First you can try to download Wincc Flexible Trial version to check accessing your project. If you succeded, then you have to order original licensed one. |
4/29/2016 8:04 PM | |
Joined: 9/7/2007 Last visit: 12/3/2022 Posts: 550 Rating:
Hi Wirsan There are many software for HMI and you need to have the configuration file first so that you can open or edit it, else you can only take an image of the HMI and download it to another one with the same part number. If you do not have this Configuration file you do not need to get the HMI software
Best Regards |
5/1/2016 7:46 AM | |
Joined: 5/28/2008 Last visit: 1/28/2023 Posts: 4377 Rating:
Hello Wirsan,
Hope this helps.
Ayman Elotaify |
5/1/2016 8:22 AM | |
Posts: 8 Rating:
Hello Ayman Elotaify. Thanks for the quick answer! I will do the recommended options. Sincerely, Wirsan. |
