11/8/2009 1:56 PM | |
Posts: 20 Rating:
Hi guys, It has become frustrating. Values in underrange (decimal: -1 ... -4k) , same card, same settings, 1 channel doesn't have QBAD, 2 others do. Have no explanation from diagnostics or documentation. Bellow is what I've tried. Details and screenshots in the attachement (low res I see but you can still make out what I'm talking about). Have your say please. Btw, I forgot to mention, PCS7 6.1
AttachmentWhy QBAD.pdf (306 Downloads) |
11/9/2009 10:02 PM | |
Posts: 2661 Rating:
Hi Lotek, Please verify the CPU settings are ok: Behavior of the QBAD signal at CH modules after station return by a faulty setting of CPU properties Regards |
11/10/2009 6:13 AM | |
Posts: 20 Rating:
Cheers mate! I forgot to mention checking that. Any other ideas? Regards! |
11/16/2009 10:01 AM | |
Posts: 183 Rating:
Hello; When QBAD=1 what's the value of the quality code? |
11/16/2009 3:17 PM | |
Posts: 20 Rating:
44 |
11/18/2009 3:26 PM | |
Posts: 183 Rating:
Hi Yer; Could you tell me what's in the MODE in BAD Driver block and in GOOD Driver block? |
