10/26/2022 8:53 PM | |
Joined: 8/12/2021 Last visit: 1/24/2023 Posts: 146 Rating:
Hi KalaDGT! You may find the following links helpful. You can find the minimum installation requirements for TIA Portal V17 in the corresponding manual and I suggest you check the compatibility with Kompatool. |
