3/24/2021 5:34 PM | |
Joined: 2/20/2015 Last visit: 4/24/2025 Posts: 9 Rating:
Hi , With Winccpro V16 , I've programmed 3 monitors with one screen per monitor (see attached file). the problem is that when the computer start (Windows 10) , the 3 screens are all on the same monitor (monitor number 1) whereas in Windows 10 each display has got a correct and different monitor number (1 / 2 / 3) . Why Wincc doesn't detect the 3 monitor ? What can we do for avoid this problem ? Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/25/2021 09:07:33New subject after splitting Automation programmer |
3/26/2021 12:08 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Check out this FAQ: https://support.industry.siemens.com/cs/de/en/view/109744837 Bye Murof |
