7/15/2022 8:47 PM | |
Joined: 1/11/2022 Last visit: 2/1/2024 Posts: 5 Rating: (0) |
Hi I Need WI004355.GSD file Can anyone have GSD files WI004355.GSD ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/18/2022 06:17:26New subject after splitting |
7/16/2022 2:02 AM | |
Joined: 9/27/2006 Last visit: 9/18/2024 Posts: 12282 Rating: (2684) |
Hello alishirvani; Normally, the creation and distribution of gsd files is the reponsability of the Profibus slave manufacturer, and it should be available on the manufacturer's website. Unofrtunately, information of the gsd file for your specfic product can only be found in very old Weidmuller catalogs (2002) with a slightly different part name (SAI-HS-DP-8DI/4DO). http://www.promsat.com//content/files/cat/weidmuller/Cat_8_Weid_Fieldbus-Components.pdf As you can see in the attached screenshot, the catalog states that it should be downloaded from the Weidmuller website, unfortnately the website declares that it does not recognize the product or the gsd file. possibly it has been discontinued, due to its age. I suggest you contact Weidmuller support to request a copy of this file, using this link for example: https://support.weidmueller.com/support-center/. Hope this helps, Daniel Chartier |
7/16/2022 5:47 AM | |
Thanks for your tips |
11/4/2023 2:23 AM | |
Joined: 1/11/2016 Last visit: 11/4/2023 Posts: 2 Rating: (0) |
Hello! Can you share this GSD file ? I cannot find this file. |
11/6/2023 5:16 AM | |
Can you share this GSD files? |
11/6/2023 6:31 AM | |
Joined: 6/27/2017 Last visit: 6/26/2024 Posts: 158 Rating: (21) |
Hello, please follow the suggestion from dchartier:
Transponder Snail |
