12/26/2010 2:21 PM | |
Posts: 4 Rating: (0) |
i need help : i want to connect absolut encoder ( GXM1W PARALLELEOUTPUT) to counter card siemens forprogramposition off machine . i want to known witch card to choose and how to connect card to encoder. im working with cpu siemens 318 . thank you. AttachmentGXM1W.pdf (161 Downloads) |
12/28/2010 6:27 AM | |
Joined: 10/7/2005 Last visit: 9/11/2024 Posts: 3020 Rating: (1054)
Hello BRmichel while my french is a bit rusty, it seems that your choosen Encoder does indeed have a 24 bit parallel output connection (12 bit resolution perturn, 12 bit multiturn resolution). What you'd need for your S7 300 to connect it are simply 24 Digital Inputs, e,g, a single 32 DI (6ES7321-1BL00-0AA0) will do the job quite nicely. I hope this helps |
Cheers |
1/3/2011 11:21 PM | |
THANK U FOR U ANSWAR . |
