5/9/2018 1:16 PM | |
hi David, it should work with your CPU and IM151. SIMATIC ET 200S Technological Functions the only thing is, that you have a Modified user data interface with an other and newer IM
hope this helps, regards,
FCK WAR! |
5/9/2018 10:03 PM | |
Joined: 11/12/2017 Last visit: 4/14/2023 Posts: 167 Rating:
Hi Mopso, Thank you for your reply. I think it should also work as the 6ES7 138-4DA04-0AB0 module does appear in the hardware configuration under my interface module IM151. Is there any reason or advantage of using the FM 350 or FM351 modules over the 6ES7 138-4DA04-0AB0 for general HSC like my application? Thanks again, David! |
6/15/2018 11:56 AM | |
Joined: 1/21/2013 Last visit: 4/21/2023 Posts: 4617 Rating:
Hello David, stupid question: but if do this job to the VFD is a problem? Ramp up/down? With STEP 7, how can you control servovalves, frequency converters ... or if you use this? |
Last edited by: Ste39 at: 6/15/2018 12:01:29 PMLast edited by: Ste39 at: 6/15/2018 12:09:50 PMLast edited by: Ste39 at: 6/15/2018 12:12:15 PMLast edited by: Jen_Moderator at: 6/18/2018 10:07:40 AMOptimized link. |
