4/5/2023 9:18 AM | |
Joined: 1/21/2013 Last visit: 9/22/2023 Posts: 2052 Rating:
Hi, If you could provide some additional information, such as software versions or more details about your problem, it would help us volunteers to provide the correct solution. Please have a look at the FAQ "Which settings do I have to make for the communication with WinCC Unified Runtime on the runtime device?", especially point 8. The simulation of a Unified Comfort Panel is always done with the WinCC Unified PC Runtime, which requires a browser for access. Kind regards |
4/5/2023 10:36 AM | |
Joined: 4/26/2012 Last visit: 9/21/2023 Posts: 1373 Rating:
Hello, from what it shows, it seems to be a user and password or "Users and Roles" error. How is the configuration of your users? see this LINK see this LINK For the simulation you can use the Automatic Login of the Runtime Manager. (Use with care as you always stay logged in using this feature). Good luck
Last edited by: Jen_Moderator at: 04/05/2023 12:11:20Link optimized. "Always make a backup before and check the best time before testing." |
2 thankful Users |
4/5/2023 10:58 AM | |
Joined: 3/22/2023 Last visit: 6/21/2023 Posts: 2 Rating:
thank you, your solution worked, I'll see later why it doesn't work with tia portal users.
