7/9/2008 3:26 AM | |
Posts: 7 Rating: (0) |
Hi Danielle: Thanks for all your help, guest what I have solved the problem. Yeah! and I create a troubleshooting procedure which I have tied with this reply and hope it could help other people dealing with the same issue. Although I did not solve the problem through “WinCC Configuration Tool” , I have discovered this wonderful tool thanks to you, it is really helpful to do modifications in the fast way to the alarm logging dabatase. Thanks a lot for your help, good luck! Sincerely, Labg.
AttachmentTroubleshoot procedure.pdf (246 Downloads) |
