5/3/2009 8:11 PM | |
Joined: 3/21/2006 Last visit: 12/2/2024 Posts: 10229 Rating: (1181) |
Hello, You can use the function SetLanguage(0x0405); Parameter in bracket is standard language code. For polish language parameter is 0x0415. Look at http://support.automation.siemens.com/WW/view/en/1405195 (WinCC Configuration Manual Manual Volume 1 4.11.1 Sample 1 - Language Switch). Hope this will helps. Best regards Hristo Mihalev |
