6/8/2009 10:26 AM | |
Hi It will be difficult without a script. You can use direct conections to manipulate the bits. here are informations about use of the bits: WinCC Information System (Help) Working with WinCC > Creating Process Pictures > Working with Objects > Working with Objects in the Object Palette > Working with Smart Objects > How to Insert a Group Display To advice you a soulution i need more informations How do you get the message variable from the PLC or how do you create the message? Do you need the acknowledgement in the PLC or otherwise. What do not function at your group display regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
