7/25/2018 8:12 AM | |
Posts: 1 Rating:
Hello trakky, I tried this migration without success. So i continue with V7.4. I'll be pleased if you could migrate it, pls share the solution with us. Thnks. |
7/27/2018 1:35 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello do you still need help? We can migrate WInCC V7.4 SP1 projects to TIA Portal V15. Look in the "Logs" folder in your project there should be logfiles also for the Migration. you can also try to use the Migration tool for a test: https://support.industry.siemens.com/cs/ww/en/view/58638200 Bye Murof |
Last edited by: Murof at: 7/27/2018 1:36:22 PMIf this Information really helps, you could use the Rate function |
8/2/2018 8:41 AM | |
Joined: 8/11/2011 Last visit: 4/17/2025 Posts: 51 Rating:
Thanks for the reply, The problem was that, it did not start the migration, so it could not create a new migrated project. That mean i could not see the log file. But TIA did not inform about this problem during migration, it's annoying...
