10/27/2014 3:48 PM | |
Joined: 2/7/2012 Last visit: 2/12/2025 Posts: 54 Rating:
I am working on upgrading the company computers with TIA V13. To do so, I had to uninstall WinCC Flex V11 Professional and WinCC Flex V12 Professional. We have multiple systems that still have V11 and V12 software on the PLC. I therefore must keep V11 and V12 working on the computers so I have to install WinCC Advanced V11 and V12 on the computers. When trying to install WinCC Advanced V11, I get multiple errors and the software will not install. I've tried installing from the disc and from the hdd with "Run as Administrator" checked. Please see attached install log. Does anyone have any ideas of what is causing the conflict and how I can get WinCC Advanced V11 to install?AttachmentSIA_WINCC_COMFORT_V11.zip (260 Downloads) |
10/29/2014 7:39 AM | |
Posts: 1299 Rating:
Hello, which operating system do you use? Did you check with compatibility tool? http://support.automation.siemens.com/WW/view/en/64847782 I would recommend you to work with virtual machines. Thismakes it easier to use different software versions. K!ke |
