4/16/2021 1:45 PM | |
Joined: 10/17/2019 Last visit: 12/5/2024 Posts: 1 Rating:
Hello, colleagues I'm using TIA Portal V16 WinCC Advanced. Faced with a problem: have opc ua server(not plc) and try to connect to it with WinCC advanced. Connection establishes but very seldom. Check the channel with kepserver opc quick client - all is good. Skada, most of the time, shows only ### ------------------------------------------------------------------------------------------ AttachmentProject2.zip (70 Downloads) |
Last edited by: Jen_Moderator at: 04/19/2021 07:36:39New subject after splitting |
4/21/2021 4:01 PM | |
Hello Check your config with the examples: https://support.industry.siemens.com/cs/de/en/view/63481236 And check that the OPC Tags do not have special Characters or umlauts (öäüß) Bye Murof |
