10/1/2015 8:48 PM | |
Joined: 9/23/2005 Last visit: 12/5/2023 Posts: 4281 Rating:
“Simple Samples” are small projects that demonstrate simple features. The target is give a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps.
Description:
By clicking on button a Report is sent to the printer.
Requirements: WinCC Advanced V13 SP1.
Project with a minimum configuration (stop button, tags, etc.).
At least one printer driver installed and set as default printer in Windows.
Configuration main steps:
References: Manual WinCC Professional V13.0 https://support.industry.siemens.com/cs/br/pt/view/92323076/en
Online helps system WinCC Professional V13.0 SP1 https://support.industry.siemens.com/cs/br/pt/view/109096785/en
Application and tools Demo projects for HMI operator panels under WinCC V13 (TIA Portal) for Basic Panels (2nd generation) and Comfort Panels https://support.industry.siemens.com/cs/br/pt/view/96003274/en
FAQ Which VBS information and VBS programming tools are there in WinCC (TIA Portal)? https://support.industry.siemens.com/cs/br/pt/view/59885894/en
Tips and tricks for creating scripts in WinCC (TIA Portal) https://support.industry.siemens.com/cs/br/pt/view/57132412/en
Project: As project.zip AttachmentProject.zip (1336 Downloads) |
Denilson Pegaia |
3 thankful Users |
2/1/2016 3:02 AM | |
Joined: 1/9/2016 Last visit: 11/13/2023 Posts: 4 Rating:
Hi Thanks!. I created Button with Cscript while press to print a report. (Erros: " ; " ) |
3/7/2017 3:25 PM | |
Joined: 9/4/2014 Last visit: 11/28/2023 Posts: 6 Rating:
hi can I change the time range of the report from script or tag ? |
