10/3/2015 12:02 PM | |
Joined: 9/23/2005 Last visit: 9/22/2023 Posts: 4235 Rating:
“Simple Samples” are small projects that demonstrate simple features. The target is give a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps.
Description:
In this simple sample, it is possible import / export recipes (one specific data record or all) from / to an archive by button click.
Requirements: WinCC Advanced V13 SP1.
Project with a minimum configuration (stop button, tags, recipes, etc. - see “WinCC Basic V13 SP1 – Simple Sample: Recipes” - https://support.industry.siemens.com/tf/br/en/posts/135157/).
Configuration main steps:
To export:
To import:
References: Manual WinCC Professional V13.0 https://support.industry.siemens.com/cs/br/pt/view/92323076/en
Online helps system WinCC Professional V13.0 SP1 https://support.industry.siemens.com/cs/br/pt/view/109096785/en
Application and tools Demo projects for HMI operator panels under WinCC V13 (TIA Portal) for Basic Panels (2nd generation) and Comfort Panels https://support.industry.siemens.com/cs/br/pt/view/96003274/en
FAQ Which VBS information and VBS programming tools are there in WinCC (TIA Portal)? https://support.industry.siemens.com/cs/br/pt/view/59885894/en
Tips and tricks for creating scripts in WinCC (TIA Portal) https://support.industry.siemens.com/cs/br/pt/view/57132412/en
Help → Visualize processes → Working with recipes → Examples (Basic Panels, Panels, RT Advanced)
Project: Attached as project.zip.
AttachmentProject.zip (477 Downloads) |
Denilson Pegaia |
2 thankful Users |
