3/6/2007 8:46 AM | |
Posts: 3149 Rating: (171)
Hi perhaps this FAQ can help? http://support.automation.siemens.com/WW/view/en/14685938 nemo |
3/6/2007 8:49 AM | |
Posts: 1084 Rating: (72)
Hi, Please take a look at the next thread, maybe the solution to your problem is listed there. With regards, Ikkezelf |
3/6/2007 1:13 PM | |
Posts: 1275 Rating: (123)
Hi, You should check the compatibility for WinCC v5.x here. As you can see in both this link and the ones Nemo and Ikkezelf posted, v5.x is not compatible with Step 7 v5.3 SP 1, and if you have Step 7 v5.2with no SPyou must use WinCC v5.1 HF0. |
