12/16/2007 12:27 PM | |
Joined: 9/27/2006 Last visit: 9/30/2023 Posts: 12153 Rating:
Hello Fabio; If the last post does not solveyour problem, Siemens FAQssuggest a third party solution, along with a sample project, here: http://support.automation.siemens.com/WW/view/en/996777 Hope this helps, Daniel Chartier |
3/6/2008 7:41 AM | |
Posts: 1 Rating:
Hi! I strongly recommend you to install WinCC localization pack for Russia (available from Siemens Moscow) and after that translate the project exactly as described in WinCC manuals. If there are any problems you may contact WinCC tech support (see wincc.ru) Good luck! Lev. |
