5/31/2014 12:50 PM | |
Posts: 7 Rating:
Hi Jens, Thanks for the reply. I'm ok with an SCL option as I already have that covered. The problem I have is that I would like the HMI to do the work as I am working on a scan time critical project and am cutting it fine. I can't attach my actual project but have attached a simple version of what I am trying to do. Please not the array sizes in my actual project are a lot bigger. basically i want to be able to input the station number in the HMI screen and use that as the array index on both the single dimension and multi dimension arrays. For the multi dimension arrays I have 10 fields on the screen so only need to use the array index in the first diemension. Hopefully you'll be able to see what i'm trying to do and you'll see the multi dimension ones in error. Kind regards, Toddy
AttachmentTempV13Proj.zip (236 Downloads) |
