8/7/2014 2:01 PM | |
Posts: 1299 Rating:
Hello, yes this is possible. you just have to change the pg/pc interface to S7Online >the network adapter which is connected to the plc. K!ke |
8/7/2014 8:15 PM | |
Posts: 27 Rating:
Hello again! I added the panel and put a on-off switch in it. With the switch i want to set Q0.5. But when i try and click on the switch something on the screen apears that says:value could not be written to the PLC. I attached some pictures of my problem. I would realy appreciate if you could have a look at the picture and tell me what i am doing wrong. Thatks for your help
AttachmentDesktop.zip (170 Downloads) |
8/8/2014 7:52 AM | |
Posts: 1299 Rating:
Hello, is the cpu running and connected to your PC? how did you set pg/pc interface (in control panel) K!ke |
8/9/2014 7:13 PM | |
Posts: 27 Rating:
Hey! Thanks k!ke the PG/PC interface was the problem :). What does the PG stand for anyway? program?
