10/3/2015 12:46 PM | |
Joined: 9/23/2005 Last visit: 12/1/2023 Posts: 4279 Rating:
“Simple Samples” are small projects that demonstrate simple features. The target is give a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps.
Description:
In this simple sample, two trends are displayed on HMI start screen.
Note: Real Time Trends doesn't retain values after HMI Power off. For retain the trends data see “WinCC Basic V13 SP1 – Simple Sample: Historical Data Trends” at https://support.industry.siemens.com/tf/br/en/posts/135198/)
Requirements: WinCC Basic V13 SP1.
Project with a minimum configuration (stop button, tags, etc. ).
Configuration main steps:
References: Manual WinCC Professional V13.0 https://support.industry.siemens.com/cs/br/pt/view/92323076/en
Online helps system WinCC Professional V13.0 SP1 https://support.industry.siemens.com/cs/br/pt/view/109096785/en
Application and tools Demo projects for HMI operator panels under WinCC V13 (TIA Portal) for Basic Panels (2nd generation) and Comfort Panels https://support.industry.siemens.com/cs/br/pt/view/96003274/en
FAQ Which VBS information and VBS programming tools are there in WinCC (TIA Portal)? https://support.industry.siemens.com/cs/br/pt/view/59885894/en
Tips and tricks for creating scripts in WinCC (TIA Portal) https://support.industry.siemens.com/cs/br/pt/view/57132412/en
Project: Attached as project.zip. AttachmentProject.zip (299 Downloads) |
12/26/2017 6:18 PM | |
Joined: 6/19/2017 Last visit: 12/1/2023 Posts: 7573 Rating:
New question published by Eng Muhammed Adel is split to a separate thread with the subject How to adjust the range of time so that the value of the tag is automatically stored?. Best regards |
12/26/2017 6:20 PM | |
New question published by Eng Muhammed Adel is split to a separate thread with the subject How can save the historical values so that the trend can remember the old values?. Best regards |
