10/3/2015 12:34 PM | |
Joined: 9/23/2005 Last visit: 12/8/2023 Posts: 4284 Rating:
“Simple Samples” are small projects that demonstrate simple features. The target is give a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps.
Description:
This simple sample shows hot to logon a user in diferent ways: By Logon system dialog (click in a specific object or – system provided – click in an unauthorized object) By button (user / password defined by variables) By button (predefined user / password)
Requirements: WinCC Basic V13 SP1.
Project with a minimum configuration (stop button, tags, user, user groups, authorizations, etc. See “WinCC Basic V13 SP1 – Simple Sample: Users – access restriction” - https://support.industry.siemens.com/tf/br/en/posts/135188/).
Configuration main steps:
Logon system dialog (click in a specific object, e.g. button)
Logon system dialog (click in an unauthorized object)
Button (user / password defined by variables)
Button (predefined user / password)
Logoff by button:
References: Manual WinCC Professional V13.0 https://support.industry.siemens.com/cs/br/pt/view/92323076/en
Online helps system WinCC Professional V13.0 SP1 https://support.industry.siemens.com/cs/br/pt/view/109096785/en
Application and tools Demo projects for HMI operator panels under WinCC V13 (TIA Portal) for Basic Panels (2nd generation) and Comfort Panels https://support.industry.siemens.com/cs/br/pt/view/96003274/en
FAQ Which VBS information and VBS programming tools are there in WinCC (TIA Portal)? https://support.industry.siemens.com/cs/br/pt/view/59885894/en
Tips and tricks for creating scripts in WinCC (TIA Portal) https://support.industry.siemens.com/cs/br/pt/view/57132412/en
Project: Due a size/ format restrictions, the project is attached as project.zip.
AttachmentProject.zip (652 Downloads) |
Denilson Pegaia |
1/21/2018 9:23 AM | |
Posts: 1 Rating:
Thanks,, |
