4/7/2022 9:17 AM | |
Posts: 10 Rating:
Same. Bump/ |
4/7/2022 2:06 PM | |
Joined: 8/3/2009 Last visit: 2/7/2025 Posts: 14670 Rating:
Hello check the following FAQ exactly on all WinCC Stations: https://support.industry.siemens.com/cs/de/en/view/108464289 These are the basics (do also the lmhosts configuration and so on...) Bye Murof |
