10/13/2022 12:16 PM | |
Hello Janja Do you have configured the lmhosts files on all systems? its very important that you do it like in this FAQ: https://support.industry.siemens.com/cs/de/en/view/108464289 Only if you work with an DNS Server the name resolution should also work without but this could also be a reason for a deisconnected Server Bye Murof |
10/13/2022 1:56 PM | |
Joined: 12/7/2018 Last visit: 6/22/2023 Posts: 13 Rating:
Thank you Murof, I didn't configure lmhosts files but there is a DNS server configured in the network, and name resolution seems fine, server and clients are all accessible between each other by name.
