11/5/2014 1:35 PM | |
Posts: 5 Rating:
Here is a project example to help you understand. The upper button is the trip state (on/off) and the Motor button is the faceplate object.
AttachmentProjectArchive.zip (207 Downloads) |
11/6/2014 6:21 AM | |
Posts: 14 Rating:
Thanks for your help. I have tested the same and now it works fine. |
11/6/2014 7:27 AM | |
Posts: 14 Rating:
Screen shot of FP_visible property (change value) attached |
11/6/2014 7:37 AM | |
Posts: 14 Rating:
I can't ope your Backup as it might be developed in V13 and i'm using wincc comfort v12 |
11/7/2014 8:32 AM | |
Posts: 1299 Rating:
Hello, can you also showhow you dynamized the visibility of the trip indication? K!ke |
