10/9/2015 12:44 PM | |
Joined: 9/23/2005 Last visit: 12/1/2023 Posts: 4279 Rating:
“Simple Samples” are small projects that demonstrate simple features. The target is give a quick overview about the theme and be used as start point for related discussions. Follow there are a short description and the configuration main steps.
Description:
In this simple sample, a set of points stored in a controller as array of variables are showed in the Trend view object by button click (the concept could be expanded by controller trigger).
Requirements: WinCC Comfort V13 SP1.
Project with a minimum configuration (stop button, tags, etc. ).
Configuration main steps:
References: Manual WinCC Professional V13.0 https://support.industry.siemens.com/cs/br/pt/view/92323076/en
Online helps system WinCC Professional V13.0 SP1 https://support.industry.siemens.com/cs/br/pt/view/109096785/en
Application and tools Demo projects for HMI operator panels under WinCC V13 (TIA Portal) for Basic Panels (2nd generation) and Comfort Panels https://support.industry.siemens.com/cs/br/pt/view/96003274/en
FAQ Which VBS information and VBS programming tools are there in WinCC (TIA Portal)? https://support.industry.siemens.com/cs/br/pt/view/59885894/en
Tips and tricks for creating scripts in WinCC (TIA Portal) https://support.industry.siemens.com/cs/br/pt/view/57132412/en
Project: Attached as project.zip.
AttachmentProject.zip (596 Downloads) |
Denilson Pegaia |
8 thankful Users |
