5/19/2017 11:58 AM | |
Hello saruky you could choose if you use WinCC V7.4SP1 or WinCC Professional V14 Sp1. It depends on if you like TIA Portal or not... But you will get another Problem!!!!! https://support.industry.siemens.com/cs/ww/en/view/109479986 So the connection Ressources of a S71200 should only wirk with 1 Adv. RT and 1 Prof RT or 2 Prof RT but not all the tree HMI systems. Bye Murof |
