4/2/2024 2:33 PM | |
Joined: 7/5/2013 Last visit: 4/22/2025 Posts: 3148 Rating:
Hello Arno, thank you for noticing this strange behavior. What do we need to solve your problem? - Is it WinCC RT Advanced? Which version?
Are you able to share the project here? Otherwise you may create a support request. Regards, Frink |
Pi is exactly three! |
4/4/2024 6:34 AM | |
Hello ArnoH do you use this example as template? https://support.industry.siemens.com/cs/ww/en/view/109481693 Bye Murof |
