4/28/2022 11:21 AM | |
Hello you can use: https://support.industry.siemens.com/cs/de/en/view/109481628 So you can use the Get PLC Mode and create an Alarm with that. You can use for example an analog alarm with low limit smaller than 5 . then you can create your Alarm. or you trigger A Script by the result and do what ever you want with this value. Bye Murof |
Last edited by: Murof at: 04/28/2022 11:21:57If this Information really helps, you could use the Rate function |
