7/27/2021 10:41 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Marek93 I Think the problem is that you use an UDT Check out this Note in the TIA Help System: https://support.industry.siemens.com/cs/de/en/view/109773785/109377913227 look here for : " Current system behavior for dynamic access to elements of a user data type" Bye Murof |
