4/20/2012 7:23 AM | |
Joined: 9/28/2005 Last visit: 12/27/2022 Posts: 2957 Rating:
Hi, What if you create project without this control ? Is it running ok ? If so then I think it will be quite hard to determine the reason. One thing I would do is to look at Windows system logs. Maybe there is something about that. Also you could try to reset WinCC Flexible to factory default state. Please also tell us what is the version of WinCC Flexible and Windows. About reseting WinCC Flexible: How can you reset WinCC flexible to the original status of the last installation? |
4/20/2012 8:23 AM | |
Joined: 3/31/2009 Last visit: 11/21/2022 Posts: 190 Rating:
Hii Darius, if i remove the activex object, the runtime will work.. br rusli |
4/20/2012 8:24 AM | |
Wincc flexible 2008 sp2 |
