7/30/2008 10:33 AM | |
Joined: 5/13/2008 Last visit: 12/18/2019 Posts: 836 Rating: (71) |
A message box is not available at WinCC flexible (see also 7. of this FAQ): http://support.automation.siemens.com/WW/view/en/26165877 On a PC RT, you have the possibility to create a workaround, by using the popup methode. Unfortunately, a Win CE panel doesn't support this. So, you have to do your own msgbox by using standard objects and/or faceplates. |
mfG / Best regards |
8/1/2008 12:23 AM | |
Posts: 9 Rating: (1) |
Well that just sucks.Why bother touting VB scripting when you cannot even display a message box. Thanks for the response |
